missing lynx wrote:49 mm carb?. I ran a rapido 225 classic will a 26mm delli and sterling exhaust with std indian gp gearbox and front and back cog it had bags of torque and would top out just over 70
dscscotty wrote:Something doesn't sound right, gearing wise sx200-46x16@4.5 @ 60mph would mean it's only only revving to around 5800rpm, with that pipe and the high duration of the exhaust port on rapido race, should hit around 7500, it's more likely over geared if anything and possibly struggling to hit peak power.
Warkton Tornado No.1 wrote:I have ran several Rapido cylinders in my time & in full race tune with only a 66 mm bore, they are capable of over 90 mph.
On the road, my opinion is that the 'race' cylinder (I have never seen a 'road' version) is best fitted with a longer stroke so that the tuning can be tamed. A 60 mm stroke crankshaft is going to be less money than yet another exhaust, but 61 or 62 mm would be even better. My SX 71 mm x 61 mm home tuned set up with a DIY 38 mm 'Clubman' pulls TV200 equivalent gearing fuss free from town speeds in top. I have no tachometer or GPS fitted but I reckon more than 80 mph is available. I'm sure there are better set ups than mine, but 'optimising' is what it's all about.
I cannot comment about n the options of exhaust you state, other than a Clubman exhaust needs a bleed (tailpipe) diameter of @ least 25 mm for that capacity.
Users browsing this forum: No registered users and 50 guests
