Casa ss200 experiences.
Postby Ballspeed65 » Wed Feb 05, 2020 10:06 pm
Hi
I am thinking of going down the ss200 route.
Does anyone have any experience of these? Good or bad, I'd like to hear.
I have been given a quote to have one fitted to include-
ss 200 kit
30 mm Polini pwk carb
SIP sport variable ignition
Already have fitted
AF race crank
Italian LI 150 box
16 46 sprockets.
Haven't decided on a pipe yet but looking at Gori gp50. Don't really want expansion but if i have to was considering Jolly Moto.
Any comments appreciated.
Ballspeed65
Re: Casa ss200 experiences.
Postby dscscotty » Wed Feb 05, 2020 11:53 pm
The ss kit ideally requires an expansion pipe, a clubman will kill it, its a little rev monster which makes its power high in the rev-range, clubman/box type pipes have usually ran out of steam by the time it wants to make decent power.
Postby Ballspeed65 » Thu Feb 06, 2020 7:19 pm
Does the Gori GP50 not rev high enough?
Ballspeed65
Postby ULC Soulagent » Thu Feb 06, 2020 10:17 pm
Indeed it does rev 8000rpm I’d think but as DSCScotty says ya need an expansion pipe too hit around the 10,000 rpm which will make the Casa sing :D
ULC Soulagent
Postby Ballspeed65 » Fri Feb 07, 2020 6:55 pm
Any recommendations?
And how good is the kit generally?
Ballspeed65
Postby ULC Soulagent » Fri Feb 07, 2020 7:18 pm
I’ve heard nothing bad about the kits so ya’s pays ur money and have a leap of faith ;)
Jolly Moto or any good rev hungry pipe will work but not gonna be cheap and expect frequent fuel stops :roll:
ULC Soulagent
Postby Ballspeed65 » Fri Feb 07, 2020 8:07 pm
Not worried about fuel stops. Im after grin factor.
I already have a rev hungry pipe. It's a soul snake curly pipe by soulscooters.
It's a good pipe but has severly crap ground clearance. So it's gotta go.
Cheers for your help.
Ballspeed65
Postby Warkton Tornado No.1 » Fri Feb 07, 2020 10:05 pm
As an aside, a 'clubman' exhaust can be fabricated to work with any engine, even if a kit works better on higher revs. I thought it reasonable to say so, regardless of your ultimate choice :)
Purely because some of us had little option other than make our own race exhausts, time was when the rules dictated a percentage of the 'original' remain, despite cones being added & metal took away for ground clearance. Despite such rules, Group Four (210 cc max) went well, as did Group Three (158cc Max), particularly Dave Webster's with it's very short 'U' pipe as compared to the 200's.
Nowadays, the clubman exhausts still follow the 60's/70's trend of having no greater ground clearance than OEM exhausts, but with a larger 'U' pipe with front cone.
With a little knowledge, the ability to cut metal & a friendly welder to hand, it is possible to create a useful exhaust based on the OEM item with an inch band cut out the side for better ground clearance, a cone/cones front & back & to select a tailpipe that will be spot on for the engine without creating heat build up. In addition, the last such item I made is fully isolated to allow it to vibrate freely, though you cannot see the isolation bobbins unless you have the floorboard off. I will be honest, the downside is that there will need to be a silencer, much like Gori & (I think) Ancilottis now have available. But @ least you have a choice of what form it may take & it's position. Don't forget that the exit (bleed) can be virtually anywhere on a two stroke exhaust, even half way along the main body.
Some of us do not always have the financial resources to buy an off the peg item, or be willing to accept the compromises such systems cause.
I hope this is food for thought :D
Postby Ballspeed65 » Sun Mar 15, 2020 11:26 pm
2 more exhausts have now been thrown into the casa ss 200 mix.
CST3 & CST5
Any thoughts on these?
Ballspeed65
Postby brumtony » Wed Mar 18, 2020 9:21 pm
Buy a quattrini kit effin awesome m8
brumtony
Postby Ballspeed65 » Wed Mar 18, 2020 11:25 pm
brumtony wrote:Buy a quattrini kit effin awesome m8
I have thought of that, but it would mean having to change my crank.
I also have reservations with a cylinder that has no skirt.
What set up do you have with that kit?
Ballspeed65
Postby Leotech » Sat Mar 21, 2020 8:49 pm
CST 3 is too low revving. all over by 7500rpm.
Leotech
Postby Ballspeed65 » Sat Mar 21, 2020 9:21 pm
Leotech wrote:CST 3 is too low revving. all over by 7500rpm.
Thanks,
If I go with the Casa ss200 that's the pipe I'll go for.
Ballspeed65
Postby Ballspeed65 » Sat Mar 21, 2020 10:22 pm
Thanks,
That is CST5!
Ballspeed65
