PHBL and PHBH dimensions ?
Postby TrackTen » Thu Jan 18, 2018 5:33 pm
Hi guys
Can anyone tell me what the dimensions are front to back of a 25mm PHBL and the same for a 28/30mm PHBH are please
Both would be rubber mount types and the dimension without the bell mouths fitted please
TrackTen
Re: PHBL and PHBH dimensions ?
Postby Storkfoot » Thu Jan 18, 2018 5:45 pm
According to Scooter Center catalogue, both are 90mm. I assume this is without a bellmouth.
Postby TrackTen » Thu Jan 18, 2018 6:02 pm
Thanks Storkfoot
I didn’t realise they had dimensions
Odd though as when I just looked it shows the phbl as 90mm and the phbh as 96.3 mm ?
TrackTen
Postby hullygully » Thu Jan 18, 2018 7:22 pm
be careful also of the distance between the centre of the venturi & the bottom of the float chamber
it can sit on your cowling :o
Postby ULC Soulagent » Thu Feb 01, 2018 5:35 pm
Phbl25 89.93mm
Phbh26 89.84mm
Phbh30 90.27mm
Not that much in it really
Postby hullygully » Mon Feb 05, 2018 7:35 pm
Hi ULC Soulagent, can you re-check the above, as I've just measured my 3 x types & get
PHBH 26 & 28mm approx. 68mm from venture (choke) to underside of main jet holder &
PHBL 30mm approx. 75mm from venture to underside of main jet holder :shock:
a 26/28mm just fits in a filter box c/w air hose & the main jet holder rests on the head cowling ;)
Postby ULC Soulagent » Mon Feb 05, 2018 9:17 pm
hullygully wrote:Hi ULC Soulagent, can you re-check the above, as I've just measured my 3 x types & get
Hi HG,
Measurement are from center of Venturi to the bottom of the main jet holder
Postby hullygully » Wed Feb 21, 2018 7:48 pm
Hi HG,
Hi ULC Soulagent, I've re-checked my verniered dims with an engineers steel rule & I'm afraid your dims aren't correct :(
Postby ULC Soulagent » Thu Feb 22, 2018 2:08 pm
Hi HG,
Oh dear :o
