PHBH 25mm on RT 195
PHBH 25mm on RT 195
Postby bluebob » Sun Jan 14, 2018 11:09 pm
Does anyone run the above through a standard air filter box under GP panels.If so which manifold is needed.
bluebob
Re: PHBH 25mm on RT 195
Postby Cgt75b » Tue Jan 16, 2018 5:16 pm
I run one on a 200 motor, you'll need the Mb manifold.
Hope that helps.
Postby daniel whiteley » Tue Jan 16, 2018 5:48 pm
https://www.riminilambrettacentre.com/e ... gomma.html
These keep the carb at a good angle to put the airbox and rubber on
daniel whiteley
