Airbox
Airbox
Postby Cgt75b » Thu Jul 27, 2017 5:24 pm
Hi peeps
What is the best way to remove the neck inside an airbox?
Thanks for any pointers.
Re: Airbox
Postby Scooterdude » Thu Jul 27, 2017 5:54 pm
The quickest and easiest way I found was to use a die grinder, quite a straight forward operation.
Scooterdude
Re: Airbox
Postby steve t » Thu Jul 27, 2017 8:29 pm
Dremel or similar with the small cutting discs you'll need 3 or 4 though they don't last long .
steve t
Re: Airbox
Postby daniel whiteley » Thu Jul 27, 2017 9:11 pm
daniel whiteley
Re: Airbox
Postby Watfordwhite » Fri Jul 28, 2017 1:35 pm
I have a brand new never used BMG big air box and fast flow filter if your interested? Powder coated white with GP scoop and all stainless nuts and bolts. £100. Cost a bit more than that, but remains unused and collecting dust.
PM me if your interested?
Watfordwhite
Re: Airbox
Postby Cgt75b » Fri Jul 28, 2017 5:10 pm
Thanks for the replies fellas. I may just run it without the airbox.
Thanks for the offer Watford white but I have other more important routes for my cash at the moment.
Re: Airbox
Postby Tractorman » Fri Jul 28, 2017 9:41 pm
You could drill holes in the airbox. If you do it on the toolbox side it's not noticeable.
Re: Airbox
Postby daniel whiteley » Sat Jul 29, 2017 5:28 pm
You could buy mine shown in the link it's painted white I fitted it and it was great then changed the engine and used a downdraught manifold and 30 mm carb so no longer needed for authentic looks
daniel whiteley
Re: Airbox
Postby Cgt75b » Tue Aug 01, 2017 5:31 pm
Gone back to a drilled airbox and seems to be running ok. Time will tell regarding reliability.
