Mikuni 35mm tmx
Mikuni 35mm tmx
Postby amb » Mon Apr 24, 2017 8:51 am
Bit of an issue with excess fuel , turn fuel on and no problems with fuel coming from the overflow on the float bowl but down the road with panel's off I've noticed fuel spitting out of said overflow and its enough to make a right mess on the engine , any suggestions guys .
amb
Re: Mikuni 35mm tmx
Postby Wack » Mon Apr 24, 2017 5:58 pm
Fit a piece of clear pipe and fasten up vertically then you will see how much overflows. Vibration may be the cause.
Re: Mikuni 35mm tmx
Postby amb » Mon Apr 24, 2017 8:54 pm
Thanks wack but what to do about it
amb
Users browsing this forum: No registered users and 30 guests
