hullygully wrote:if anything the plastic would wear first
St George wrote:Had this before, the nylon reduces in size due to over tightening, unlike rubber does not expand.
St George wrote:Learn every day. Glad it's sorted.
coaster wrote:The nylons do wear but so do the manifolds. If fitting a new nylon doesn't cure it you will need a new manifold. This was a common problem back in the 60s/70's
