choke on, no start
choke on, no start
Postby eyeguy » Sat Apr 15, 2017 11:55 pm
So when I try to cold start my Li special with choke on it acts like it's flooding. It starts when not using choke although it takes a few kicks, probably because it is flooded by then. I did clean all sets and replaced seals. needle didn't seem to be sticking. float seems free. I had the choke plunger moving all the way up when choke on. I did adjust to only open half way, but didn't help.
Any thoughts
eyeguy
eyeguy
Re: choke on, no start
Postby MickYork » Sun Apr 16, 2017 8:16 am
air filter clogged, pilot jet too big, choke jet too big.............post up your carb'/engine spec' and you'll get more replies.
Postby CHRIS in MARGATE » Sun Apr 16, 2017 8:29 am
Always done it or just started doing it ?
Are you keeping throttle shut when kicking it over ?
Postby eyeguy » Sun Apr 16, 2017 12:58 pm
Air filter new. Need to remove carb and check jet sizes. I suspect they are stock as the scoot is original. Sat in a garage for over twenty years.
Since I got it it's acted that way.
Thanks I'll get those sizes
Eyeguy
eyeguy
Postby eyeguy » Sun Apr 16, 2017 1:33 pm
Okay according to sticky the jets are all standard 101,45,50. Li 150 Special series 3 1964
eyeguy
eyeguy
Postby eyeguy » Sun Apr 16, 2017 3:38 pm
I am keeping throttle off when starting
eyeguy
eyeguy
Postby St George » Fri Jun 09, 2017 5:14 pm
Have you tried getting an aerosol of car cleaner and blasting the whole carb, about £6.00 but will last for years. Regards SG
St George
Postby Hornbyfrog123 » Fri Jun 09, 2017 5:59 pm
Is air mixture screw set correctly?
Hornbyfrog123
