TS1 225 stroking
TS1 225 stroking
Postby ROClarke » Sun Apr 02, 2017 11:11 am
Hi Guys
I have a PHBH30 with a what I think is a power jet.
Main 135
Pilot 53
Choke 70
Slide 50
Atomiser AV 268
Needle ?
Float valve 400
The scoot seems to be 4 stroking on half throttle but takes off when I give it a hand full and runs nicely flat out.
This morning I took the carb off to se if the needle could be lowered anymore,but it is already on the last grove.
Is the small screw next to the idle adjustment larger screw for mixture adjustment throughout the range is will it only effect tick over mixture ?
ROClarke
Re: TS1 225 stroking
Postby col68 » Sun Apr 02, 2017 3:19 pm
Hi mate run my ts with a av266 and x13 needle second clip from top dynoed by alan at diablo moto hope this helps . Revs well no four stroking. col
col68
Postby bike grim » Sun Apr 02, 2017 4:21 pm
What exhaust?
Postby ROClarke » Sun Apr 02, 2017 5:24 pm
bike grim wrote:What exhaust?
Exhaust is JL3 was fitted when I bought the scoot
ROClarke
Postby Rich Oswald » Mon Apr 03, 2017 12:20 pm
col68 wrote:Hi mate run my ts with a av266 and x13 needle second clip from top dynoed by alan at diablo moto hope this helps . Revs well no four stroking. col
Agree with this, change atomiser to AV 266 and maybe even an X7 needle if still boggy mid range. Do plenty of plug chops though.
Postby ROClarke » Mon Apr 03, 2017 10:30 pm
Ok will give it a try.
ROClarke
Postby dscscotty » Tue Apr 04, 2017 1:47 am
You say its power jetted, can you confirm? I tend to run AV268 Atomisers with x7 in PHBH on TS1's
Postby ROClarke » Tue Apr 04, 2017 7:10 pm
dscscotty wrote:You say its power jetted, can you confirm? I tend to run AV268 Atomisers with x7 in PHBH on TS1's
Yes, I am sure it is a power jet, it has a tube coming from the float chamber I seem to recall connected to some sort of jet on the side of the carb near the intake.
ROClarke
Postby rossclark » Fri Apr 07, 2017 12:30 am
Doesn't sound like the standard power jet on this type.
Maybe post a picture?
Postby ROClarke » Sun Apr 09, 2017 9:50 pm
Fitted the AV266,what a difference,runs much better in the low rev range.
ROClarke
Postby Rich Oswald » Mon Apr 10, 2017 12:58 pm
Rich'[/quote]
Cheers[/quote]
Fitted the AV266,what a difference,runs much better in the low rev range.[/quote]
Glad to hear that mate, keep an eye on your plug colour,
Postby ROClarke » Mon Apr 10, 2017 7:51 pm
Rich Oswald wrote:Agree with this, change atomiser to AV 266 and maybe even an X7 needle if still boggy mid range. Do plenty of plug chops though.
Cheers[/quote]
Rich'[/quote]
Not checked plug colour yet,enjoying the new drive ability too much!
ROClarke
Postby hullygully » Tue Apr 11, 2017 10:17 am
be carefull............................. :? do what uncle Rich says yoof 8-) :lol:
Postby ROClarke » Tue Apr 11, 2017 9:47 pm
hullygully wrote:be carefull............................. :? do what uncle Rich says yoof 8-) :lol:
Nah it is fine no pinking or anything,but just to keep you happy I will check it,what am I looking for ?
ROClarke
Postby Toddy » Wed Apr 12, 2017 6:12 am
I think the lads mean do some plug checks through all throttle ranges to see its ok in all areas :D
Postby ROClarke » Tue Apr 25, 2017 11:20 am
I cannot seem to get the plug colour the nice chocolate colour, even when it is 4 stroking the electrode is light brown but very wet and the outside of the plug is black and wet.
The scoot is running much better now though and I am tempted to leave it but part of me would like to get the pug colour right.
Any help appreciated
ROClarke
