Return of the Jetex
Return of the Jetex
Postby P D: SC Chester » Tue Feb 14, 2017 8:28 pm
After throwing away the top for my Mikuni by accident, or more correctly- stupidity. I've had to re fit my old 22mm jetex. The problem I seem to have is excess fuel spit back. I don't recall it doing this previously and the main is 118 with a 50 and (atomizer??).
Does it sound like the float is sticking open? It also runs like a bag of crap, and will only tick over with a lot of revs.
Any ideas chaps?
P D: SC Chester
Re: Return of the Jetex
Postby EddieStone » Wed Feb 15, 2017 10:09 am
Check the slide is the right one
EddieStone
Postby St George » Wed Feb 15, 2017 6:49 pm
There are loads of threads on this. I fitted Delly jets to mine and ran a small drill through the float.
St George
Postby Toddy » Thu Feb 16, 2017 7:00 am
St George wrote:There are loads of threads on this. I fitted Delly jets to mine and ran a small drill through the float.
Agree if you type in Jettex in the search option there are quite a few threads
Postby P D: SC Chester » Fri Feb 17, 2017 12:05 am
My eBay 15.99 Mikuni carb arrived today, fired up second kick and ticks over great.
It's a 28mm and probably a copy, but it sure makes a difference compared to the medieval Jetex.
P D: SC Chester
