25 mm dellorto
25 mm dellorto
Postby jefft » Sat Jan 21, 2017 10:36 am
Hi all,
I have just changed my inlet manifold to a shorter one and fitted a 25 mm dellorto carb which I want to connect to the standard air box using a GP flexible hose. (Previous owner had intended to drill out the side panel and fit a air scoop )
I chose the GP hose as it had the largest diameter hose openings but it's a bit big to couple onto the carb . Does anyone know of some sort of adaptor that will allow me to connect to the 25 mm phbh dellorto.
Jefft :?:
jefft
Re: 25 mm dellorto
Postby HxPaul » Sat Jan 21, 2017 11:46 am
MB do a kit for that set up,in that they use a GP125 air hose,this is the same size as fits on a standard sh/1 20mm carb.
Re: 25 mm dellorto
Postby Mag » Sat Jan 21, 2017 1:12 pm
HxPaul wrote:MB do a kit for that set up,in that they use a GP125 air hose,this is the same size as fits on a standard sh/1 20mm carb.
Thats right, it is the GP125 hose, not the GP200 one. I have that set up on one of my GPs and also found I couldn't use the original GP filter elbow either, it has to be the LI/SX type as they are a different length.
Mag
