Cleaning the outer case of a Dellorto carburettor
Postby Big Al » Fri Dec 30, 2016 1:39 pm
I have thoroughly cleaned the inside of my carb, including jets and slide, etc.
Could someone please suggest a good and effective cleaner for the outer casing? No acids or explosive mixtures please!
Big Al
Re: Cleaning the outer case of a Dellorto carburettor
Postby Warkton Tornado No.1 » Fri Dec 30, 2016 3:37 pm
If you don't have access to an ultrasonic cleaner, you can try the 'Oxy' type laundry cleaners with boiling water.
They do get a lot of the cr@p off, in my experience & leave the zinc surface with a 'consistent' finish which stays reasonable if immediately coated with something like WD40.
I hope that helps.... :)
Postby Storkfoot » Fri Dec 30, 2016 5:50 pm
Just use a generic carb and brake cleaner. Halfords sell it. They are good for inside and outside.
Edit: it's actually "air intake and carburettor cleaner"
Postby Big Al » Fri Dec 30, 2016 6:29 pm
Many thanks guys.
Big Al
Postby Fast n Furious » Sat Dec 31, 2016 5:00 am
Wait until she goes out, then, stick it in the dishwasher and auto blast it at 70 degrees. (not the plastic bits). Now crack open a cold one. You deserve it.
Postby rexton270s » Sun Jan 01, 2017 10:13 am
:lol:
Fast n Furious wrote:Wait until she goes out, then, stick it in the dishwasher and auto blast it at 70 degrees. (not the plastic bits). Now crack open a cold one. You deserve it.
rexton270s
