TS1 30mm dellorto carb settings
Postby ladsdad » Tue Nov 15, 2016 11:16 am
Hi all
Would anyone be able to give me some base carb settings for a mildly tuned TS1 225, dellorto phbh 30mm running initially with a bgm clubman. I thought I'd see this question posted before but I've had a look & just can't find it so....... :)
Any guidance much appreciated thanks.
Cheers Mark.
ladsdad
Re: TS1 30mm dellorto carb settings
Postby Rich Oswald » Tue Nov 15, 2016 1:23 pm
ladsdad wrote:Hi all
Cheers Mark.
Mark, I have just given this to Toddy also, and this is what I ran on mine but with a Franspeed Supertourer and it went really well with no bogging and good plug colours throughout:-
Main 135
Pilot 55
Choke 70
Slide 40
Atomiser AV 266
Needle X7
Float Valve 200
N.B. This is only a guideline and not a recommendation without Dyno and / or plug chops.
Hope this helps you a bit Mark,
Postby Strummer10 » Mon May 01, 2017 12:48 pm
Cheers Mark.
Main 135
Pilot 55
Choke 70
Slide 40
Atomiser AV 266
Needle X7
Float Valve 200
Found this researching my issue. I have a BGM Clubman and a PHBH 30mm also was gonna follow the above to get started and maybe go ram breathe easy after a while of running open mouthed (which I can deal with later)......any idea on the above set up where the needle position would sit ?
AND....if I go with a breathe easy filter, presumably would just up jet it ?
Strummer10
Postby hullygully » Mon May 01, 2017 6:21 pm
carefull with that float valve, are you sure it wasn't a 300? :?
Postby Strummer10 » Mon May 01, 2017 7:26 pm
No its definitely a 200 float valve, I think the Carb (second hand new) must have been set up for a 150 small block previously......Looking at tables it seems the 200 float valve was used in some Imola 185 set ups.
Strummer10
Postby Rich Oswald » Tue May 02, 2017 9:56 am
hullygully wrote:carefull with that float valve, are you sure it wasn't a 300? :?
I should have recommended a 300 float valve Mickey as that is what I was running. Sorry for the error.
The needle was on P2 (from the top).
Postby ladsdad » Tue May 02, 2017 10:32 am
Lucky someone's paying attention.... Cheers Mickey.
ladsdad
Postby Rich Oswald » Tue May 02, 2017 11:59 am
ladsdad wrote:Lucky someone's paying attention.... Cheers Mickey.
:shock: ;)
Postby Toddy » Tue May 02, 2017 12:13 pm
Makes a change from his navigation skills ;)
Postby Simon_T » Fri Mar 09, 2018 9:34 pm
Richard what gearing was run on this please>>?
cheers.
Cheers Mark.
Main 135
Pilot 55
Choke 70
Slide 40
Atomiser AV 266
Needle X7
Float Valve 200
Simon_T
Postby hullygully » Tue Mar 13, 2018 7:42 pm
:oops: :roll: :? :( :| :?:
