34mm dellorto
34mm dellorto
Postby Wilson » Thu Oct 06, 2016 2:55 pm
anyone got carb settings for a ts1 running a 34mm dellorto,franspeed super tourer with a bgm stator and Indian flywheel with timing set at 18 degrees.brand new build will have it dynoed next week just want to clear up the bogginess at low speeds,
Wilson
Re: 34mm dellorto
Postby Adam_Winstone » Sat Oct 29, 2016 5:43 pm
Sorry, not I but as this looks very much like the 'text book' configuration for a TS1, it should be extremely common and I'd have thought that plenty of people should be able to offer you details of their similar setups (?!).
Good luck.
Re: 34mm dellorto
Postby Toddy » Mon Oct 31, 2016 7:16 am
I think if you go on the AF Rayspeed Website there are Carb set up recomendations for the 34mm on a TS set up
Re: 34mm dellorto
Postby johnnyXS » Mon Oct 31, 2016 10:38 am
the scooterotica site used to have a huge thread dedicated to carb setups ;)
http://www.scooterotica.org/forum/viewtopic.php?f=9&t=14
johnnyXS
