Gori 50 & Dellorto 30
Postby DaveTomo » Sat May 31, 2014 11:12 am
Right I'll start the ball rolling.... Anyone running a Gori 50 box pipe? After a starting point on a 225,previously run a 48 mm clubman & the carb was Dellorto 30 PHBH open mouth hole in the panel,tea strainer filter
atomiser/needle jet AV266
main jet 122
float jet 300
X7 needle second clip
40 slide
55 pilot
choke 70
mixture screw 3 turns out.
BGM stator set at 17 BTDC static
Now I thought (foolishly) it wouldn't be much different,but bogs quite dramatically around 1/2 throttle upwards so I'm presuming it makes its power totally different to the clubman.Anyone running this combo be able to give me an idea of there set up please?
DaveTomo
Re: Gori 50 & Dellorto 30
Postby Rich Oswald » Sat May 31, 2014 11:29 am
Not running a Gori Dave but have the same set up on 225 Mugello with Taff Mk 4. Have you tried top clip as moving up a clip worked for me when mine was boggy mid range.
Postby DaveTomo » Sat May 31, 2014 4:13 pm
Cheers Rich, I'll give that a go tomorrow & let you know how I get on
DaveTomo
Postby DaveTomo » Mon Jun 02, 2014 11:08 pm
Cheers Rich,moved up 1 clip , sorted 8-) done a few plug chops & choke test, all good.Must admit I was a bit wary of going onto the top clip ,but the engine seems happy,so thank you mate
DaveTomo
Postby Rich Oswald » Tue Jun 03, 2014 3:11 pm
No worries Dave, just keep an eye on plug colour at mid range that's all.
Users browsing this forum: Bing [Bot] and 35 guests
