Foam glue
Foam glue
Postby Wack » Mon Jul 18, 2016 5:34 pm
Apart from superglue can anyone recommend a glue to stick a Ramair foam filter to a rubber mouth? I asked Ramair but received no reply as to what they use as I want to stick an off centre mouth on .
Re: Foam glue
Postby steve t » Mon Jul 18, 2016 8:01 pm
Have you tried contact adhesive the rubber bell mouth might need a key up though
steve t
Re: Foam glue
Postby Wack » Mon Jul 18, 2016 8:36 pm
Can't see contact working especially where petrol is involved. The off centre mouth was an old red Malossi one and the foam was held with a resin type glue that was very hard to remove, did it with a craft knife a bit at a time but I don't think araldite will do the job even with a key on the rubber.
Re: Foam glue
Postby steve t » Mon Jul 18, 2016 8:49 pm
At work we bond rubber to steel mainly conveyor based the rubber lining lads Bond foam to concrete for use in vets drop down boxes we only use 1 type of glue it's called rema tip top sc4000 definitely oil resistant not sure about petrol though but its expensive sticks like sh@t to a blanket
steve t
Re: Foam glue
Postby Mel K » Mon Jul 18, 2016 9:13 pm
http://m.ebay.co.uk/itm/5-Min-Epoxy-Res ... nav=SEARCH
I was bored so had a look on eBay for you
Never used it myself but it's cheap and the description looks like what you need .
Good luck .
Mel K
Re: Foam glue
Postby Wack » Mon Jul 18, 2016 9:57 pm
Thank you for heads up on the resin although the stuff Steve t uses sounds good.
Re: Foam glue
Postby Wack » Tue Jul 19, 2016 9:57 pm
Looks like Gorilla glue does the job ;)
