30mm PHBH on 225 rapido classic
Postby drivera » Sat Jul 09, 2016 5:32 pm
Anybody got jetting details for the above set up , running a 48mm Fresco ?
drivera
Re: 30mm PHBH on 225 rapido classic
Postby MickYork » Sat Jul 09, 2016 5:40 pm
Used to have one......i'd start with;
Pilot: 57
Slide: 40
Needle: X7
Atomiser: AV266
Main: 125
Obviously plug chop at different throttle positions.
Postby Rich Oswald » Sat Jul 09, 2016 5:50 pm
I run the same with BGM Clubman:-
AV266
X7
40 slide
52 pilot
122 main
70 choke
300 float valve
Running with a breathe sweet filter
Postby DaveTomo » Sat Jul 09, 2016 11:20 pm
Had one running a 48mm clubman open mouthed with a tea strainer filter -may get you somewhere near (pretty much the same as previous answers)
AV266
X7 - 2nd clip
40 slide
55 pilot
122 main
70 choke
300 float valve
DaveTomo
Postby Swat » Sun Jul 10, 2016 9:36 pm
Pilot: 57
Slide: 40
Needle: X7
Atomiser: AV266
135 main jet
ramair filter onto bellmouth
set up on the A64 'dyno' by Kempy
it's a bit 'bronchial' from cold and/or standing start but clears her throaght above 4k revs - just dropped needle to 2nd lowest setting (i.e circlip on next to top groove) and runs a bit cleaner
Swat
Postby Rich Oswald » Mon Jul 11, 2016 11:51 am
Swat wrote:Pilot: 57
Slide: 40
Needle: X7
Atomiser: AV266
135 main jet
it's a bit 'bronchial' from cold and/or standing start but clears her throat above 4k revs - just dropped needle to 2nd lowest setting (i.e circlip on next to top groove) and runs a bit cleaner
Would that not be due to the rather large Pilot Jet then Swat?
Postby Swat » Mon Jul 11, 2016 3:39 pm
Quite possibly Rich,
I bow to Ray's experience & have left it 'as is' (for 3yrs now) I do think it does run too rich at low speeds - as evidenced by the oiled plug (BR9 ES) i had on the saturday genteel runout to Prichenstadt at the Euro. However, you know the saying "fiddle, fiddle, F**cked" so I leave carb settings well alone
I do however, still have my orange paint touch up pen !
Swat
Users browsing this forum: Bing [Bot], Google [Bot] and 43 guests
