Jetting for 25mm Dellorto + S2 42mm Clubman
Hi all
I'm going to put my Casa 42mm S2 clubman exhaust on my S2 li150 this weekend.
Carb is new Dellorto 25mm phbl
Open mouthed at present ( I can't get a rubber elbow to fit properly on the standard ( but drilled) air box - the carb mouth seems too offset compared to the standard ones)
Has anybody got a similar set up and could advise what jetting to use as a sensible starting point?
