26mm dellorto settings
Postby Omega 7 » Sun Jun 19, 2016 7:55 pm
I'm thinking of putting a 26mm phbh onto a standard gp200, clubman exhaust and through the air box. Anyone got a similar set up or any idea of a starting point for the jetting. Thanks
Omega 7
Re: 26mm dellorto settings
Postby hullygully » Mon Jun 20, 2016 5:23 pm
I had lots of fun (not) jetting mine, run thru drilled & hollowed out airbox, side panel compressed carb rubber due to NOT using a Broady carb rubber, during a recent re-build I managed to take another 3/5mm off the manifold, hence pushing the rubber back a smudging further. 8-)
Postby dave411 » Mon Jun 27, 2016 4:13 pm
What is a Broady carb rubber?
I have a problem with my air intake rubber fouling on the side panel.
dave411
Postby hullygully » Mon Jul 04, 2016 6:26 pm
the rubber that holds the carb onto the manifold, its about 10mm shorter than the VE one I originally used
