LAMBY COUGHING AND SPLUTTERING
Postby Bluenose1 » Thu Jun 09, 2016 11:06 am
Gents, my scoot is coughing and spluttering popping and farting from the off up to about 1/2 throttle, once it hits the main jet, goes like stink. CDI changed, stator changed, AF light flywheel was removed, and normal flywheel added... Running a 30mm delly ( open mouthed ) 200cc indian stage 4 ish barrel, ScootRS exhaust... Any ideas ? :(
Bluenose1
Re: LAMBY COUGHING AND SPLUTTERING
Postby Toddy » Thu Jun 09, 2016 12:11 pm
Needles not loose in the slide (Clip dropped off ? ) what the jettings in it ?
Postby johnnyXS » Thu Jun 09, 2016 1:31 pm
well the throttle pickup off of idle is controlled by the slide, the pilot jet and the air/fuel mixture screw so I would be looking to see if I had a partial blockage somewhere in the idle circuit or possibly an air leak somewhere.
The needle , main jet etc plays no part in throttle response off idle up to well past 1/4 throttle opening.
Try putting about 1/4 to half choke on and then blipping the throttle . If it picks up better then you have a fuel flow problem (pilot jet atomiser etc) if it is worse then you probably have an air leak problem somewhere or your pilot jet is too rich.
I'm assuming that this carb setup has worked properly previously and isn't a fresh addition ?
http://www.ducatimeccanica.com/dellorto_guide/dellorto_3_4.html
johnnyXS
Postby Warkton Tornado No.1 » Fri Jun 10, 2016 3:49 am
If your carburetion & ignition timing is identical to what you previously had (you’ve strobed it, of course?) & the only change is flywheel weight & it ran well before, I would suspect something duff in your new components.
