Spitting from open mouth carb
Postby puggie6653 » Mon May 23, 2016 3:27 pm
Hi guys and gals, I'm having problems with my ts1, everyone tells me it's running rich and spits out a lot through the open mouth carb, but I don't really why this is ( rich wise ) or do all carbs put out through the bellmouth.
I am using 30mm phbh carb , 135 main, 65 pilot, Av 268 atom , 50 slide , x7 needle 2nd from top , mixture 1 and 3/4 out. Ngk br9 plug, which is always oily on plug checks , bike runs good and averages about 35mpg, with all my gear and me 18st ish , don't know where to turn .Any advice greatly received
puggie6653
Re: Spitting from open mouth carb
Postby col68 » Mon May 23, 2016 5:58 pm
Hi I run with a Av226 , x13 needle 2nd clip from top , 55 idle and a 135 main with ramair fillter and jl3 pipe runs nice and clean with that setup . hope this helps . col
col68
Postby Warkton Tornado No.1 » Mon May 23, 2016 6:42 pm
Spit back should almost be eliminated with reed valves, that being the point of ‘one way traffic’ ensuring entrapment of the charge.
Your reeds should be your first check.
However, pilot jet 65 sounds way too rich (Rayspeed suggest 55), as does an AV268 (Rayspeed suggest AV266 & slide 30 - 40)
Postby puggie6653 » Mon May 23, 2016 7:23 pm
Thanks guy for the info
puggie6653
Users browsing this forum: Google [Bot] and 48 guests
