Float weights
Float weights
Postby gp200ts1 » Fri Mar 04, 2016 6:11 pm
What effect will using a heavier float in my carb be? I have a 30mm phbh and the float has developed a leak. I have a selection of nos floats that I picked up from a dealer years ago, only thing is they range from 3.3 grams up to 11.7 grams and none of them are 5 grams like my leaky one. What would the result be of using a heavier or lighter float?
gp200ts1
Re: Float weights
Postby bendyminge » Sat Mar 05, 2016 12:27 am
From Google.....
"A heavy float will cause the carburetor to dump a rich mixture into the combustion chamber. The engine will foul the spark plug quickly and use more fuel than expected."
Ben
bendyminge
Users browsing this forum: Bing [Bot] and 42 guests
