Vhb 30mm needles
Vhb 30mm needles
Postby Kelly » Sun Jul 05, 2015 3:30 pm
Vhb 30mm carb needles are the needles different lengths , i have a v5 and v9 that are longer than a v3 , is that right i just bought the v3 needle and its shorter or can you get longer v3 needles ?
Kelly
Re: Vhb 30mm needles
Postby Warkton Tornado No.1 » Sun Jul 05, 2015 6:10 pm
As far as Eurocarb, they currently only list V type Needle (VHB(T) 27-30mm) in the following type:
V1, V3, V5, V7, V9, V10, V12-V14 inclusive.
They have a chart with detail of the variations on their website:
http://www.dellorto.co.uk
You may find some elsewhere & @ a better price. Please let me know if you do.
Postby Kelly » Sun Jul 05, 2015 6:57 pm
Ok thanks so the v3 needle is shorter 73.5 and a v5 is 78.5 thanks for the help , i got the v3 needle from the usa for about £8 posted
Kelly
Postby Warkton Tornado No.1 » Sun Jul 05, 2015 8:04 pm
What atomiser & slide are you intending to use?
Is yours the type with a non removable needle valve? I've never seen one that is removable.
Postby Kelly » Sun Jul 05, 2015 9:00 pm
Atom is 265n 7554.50 slide i dont know to much about these carb tbh , from memory i think it is removable but id have to take off the bike to find out
Kelly
Postby Warkton Tornado No.1 » Mon Jul 06, 2015 2:26 pm
You have the closest that was ever made to being suitable for two strokes with the 'N' atomiser. So that's good.
Slides available are limited, but there is a modifacation that can be done, if required. You should be in the right ball park with a 50, though.
The reason I mentioned non removable needle valves & that is all I've ever seen, is that the fuel flow rate is restricted & you can only improve by opening up the holes so much. These days, with grunty, big bore barrels, longer stroke as even I have(!) there is a concern that suficient fuel can get into the carb to be delivered.
I have a carb, very much work in progress, that I have converted to take a two stroke atomiser from the PH range. There is still the problem of finding needles suitable, though.
I need to dig it all out soon & crack on!
Postby Kelly » Mon Jul 06, 2015 4:43 pm
I know what you mean about the needles took me a year and a half to find the v3 then panicked when i thought i was the wrong length lol
Kelly
Users browsing this forum: Bing [Bot] and 50 guests
