Ballpark Jetting suggestion
Postby Rich Oswald » Thu Jun 25, 2015 9:45 pm
Looking for a ballpark jetting for 30mm PHBH on a tuned TS1 with Franspeed supertourer. This has just replaced a 35mm TMX which I was struggling with and have been advised to try this carb'.
At moment it has:-
Main 135
Pilot 55
Choke 70
Slide 40
Float 300
Needle X7
Atomiser AV266
Cheers,
Re: Ballpark Jetting suggestion
Postby Storkfoot » Thu Jun 25, 2015 10:32 pm
I have a standard TS1 225 with a Supertourer. Li150 gearbox 16/46.
My settings are the same as yours except I have an AV264/x13 2nd clip from top of needle. This is with a RamAir straight on the bellmouth and out through the panel.
It went on a dyno over a couple of years ago and the air/fuel ratio was found to be within accepted limits all the way through the throttle progression.
If yours is tuned, you may want to start with a slightly bigger main jet :idea:
Postby Rich Oswald » Thu Jun 25, 2015 10:44 pm
Great, thanks Storkfoot. All imput welcome.
Postby Rich Oswald » Fri Jun 26, 2015 1:47 pm
Eden wrote:I would put at least a 350 float needle in.
OK cheers Eden
Postby bsso78 » Fri Jun 26, 2015 4:21 pm
Depends on what you mean by tuned but Eden is right, other than that you should be somewhere near.
bsso78
Postby Rich Oswald » Fri Jun 26, 2015 8:05 pm
bsso78 wrote:Depends on what you mean by tuned but Eden is right, other than that you should be somewhere near.
That's just the point Barry, I don't know myself although you might. I bought the scooter off Gary O'Hagan, it was his Series 2. He didn't seem to know the state of tune, maybe you or Scotty know???
Postby bsso78 » Sat Jun 27, 2015 9:49 am
Well in that case!
From what i remember its only mild, not much more than polishing and tidying really. I think i put the top end together for him but im not really sure now :?
Anyway i know its a decent motor with quality parts fitted, you might want to come down a bit on the pilot but leave it how it is now and take it for a spin first and see what its like.
bsso78
