looking for better carb
Postby garynonnah » Thu Jun 25, 2015 9:26 pm
running std sil 200 eng on my gp......which i rebuilt, decent oil seals/bearings mec gp crank
done 800miles....using jetex 24 mil with 122 jet.....
but had couple heat seizes, bore/piston ok....been using wrong oil mixture.
wondering if using bigger or different carb would improve things....
garynonnah
Re: looking for better carb
Postby Donnie » Fri Jun 26, 2015 10:43 am
Im unsure how using a bigger carb or any other carb will improve how you mix your oil? :?:
Donnie
Postby missing lynx » Fri Jun 26, 2015 7:34 pm
is it a std sil barrel and piston ? is it a bored out 22 carb as a 122 main jet would be about right for a 22 but a bit on the small size for a 24 also indian top ends are a bit on the tight size so if thats what you've got it may be worth getting it honed out
Postby pip » Sat Jun 27, 2015 9:40 am
Jettex aint great when bored out from standard size, Ive fitted a Dellorto 25 mm phbl on mine and works a treat.
pip
Postby Paulnobodyimportant » Sat Jun 27, 2015 7:03 pm
Plus, recommended main jet for a SIL 200 & Indian big bore is 123. However, on this setup, I had minor heat seizes. Put 125 main jet in and no problems since. Don't know how you go on with it reamed to 24, but at least try a 125 main before scrapping carb. I run mine on 2% oil mix.
Paulnobodyimportant
Postby hullygully » Mon Jun 29, 2015 10:31 am
had to go up to a 130 on my Gori with the bored out jetex & up to 135 on my tuned 175 :o :o :o
check your pilot too
Postby Dimitrios_231 » Mon Jun 29, 2015 8:00 pm
Original Dellorto SH2/24 carbs are using a 55 pilot jet,
main jet 130 minimum (128 at hot Greek weather)
Dimitrios_231
Postby garynonnah » Mon Jun 29, 2015 9:25 pm
Thanks for all the info...food for thought :D
garynonnah
Postby corrado » Sat Jul 18, 2015 12:23 pm
I'm not sure why people persevere with Jetex carbs, it must only be 1 in every 4 that works properly. If you want standard looks and performance go with the remade [as per Dellorto] 22mm carb from Scootopia, UK made. Or for slightly better performance a Dellorto PHBL25, still run through an airbox for standard'ish looks.
corrado
