Needle clip - too weak or too rich
this is doing my head in...
Phbh 30 on rt225(230 with 60 mm crank)
Just to the end of running in now so time to sort the lumpy richness that you patiently have to live with at these times.
I've got it spot on to 1/4, by changing the slide to a 50, mixture is 2 turns and ticks over nicely, over 3/4 is spot on, picks up very nicely but that while mid throttle, atomiser and needle range is all over the place.
Initially had an av266 Needle jet with an x2 needle. It was too rich on 3rd clip and too weak on last clip. Just put in an av264, same needle, it's too rich on 2nd clip and too weak on the 3rd. So by changing the atomiser I've moved the problem down the needle but no closer to solving the issue. I suspect I need to change the needle but not sure if I'm looking leaner or richer.
What say the oracle?
