Mikuni TMX 30 powerjet
Postby smiffy » Sat Apr 18, 2015 12:08 pm
Need to change the throttle cable elbow on my Mikuni tmx 30 powerjet carb to fit long range tank, what i need to know is does it actually screw off? seems very tight and i dont want to force it. If its not a screw in is bending it an option. maybe with a little heat?
Anyone had the same problem?
Cheers.
smiffy
Re: Mikuni TMX 30 powerjet
Postby peter357bikes » Sat May 09, 2015 7:16 pm
my two mikuni tmx 30 are I believe push fit...couldn't get them out.(drilled one out in the end)..gentle heating may succeed.....
peter357bikes
Postby smiffy » Fri May 15, 2015 6:15 am
Thanks mate.
smiffy
