VHSH... what is it?!
PostPosted: Wed Apr 15, 2015 2:00 pm
by Adam_Winstone
All,
Last night I stripped down a VHSH 30 to fit to a motor and a tiny little brass part (small solid cylinder about 3mm long) and tiny fitted spring fell out of it. Any ideas as to what it is and where it goes?
Ta
Adam
Re: VHSH... what is it?!
PostPosted: Wed Apr 15, 2015 4:36 pm
by Captain Pugwash
PM sent
PostPosted: Wed Apr 15, 2015 4:38 pm
by bolzenanker
Adam
I've got one at home that I've changed jets on before and don't recall anything like that. I'll have another look later if I get a chance and report back.
Warren
PostPosted: Thu Apr 16, 2015 6:27 am
by Toddy
Will this help theres a PDF parts diagram on the link
http://www.dellorto.co.uk/merchandise/p ... ctionID=42
PostPosted: Thu Apr 16, 2015 8:18 am
by Adam_Winstone
I couldn't see this part on the exploded diagram but here it is...
PostPosted: Thu Apr 16, 2015 12:17 pm
by Toddy
Is it off the threaded bit what screws into the top of the slide that the cable goes through ? doesnt that have a spring underneath (sits on top of the Needle )
PostPosted: Thu Apr 16, 2015 12:57 pm
by Markpm
It looks like the choke plunger to me ??
Or an atomiser bush (had a look at diagram )
PostPosted: Thu Apr 16, 2015 1:44 pm
by Adam_Winstone
It does look like that sort of thing but this (body) is only 5mm long at most, way too small for choke use.
The exploded parts diagram and Eurocarb parts list don't seem to show it.
I'll need to have a really close examination of the carb again to see if I can identify it or where it should go, what it should do. The good news is that the carb seems to work without it! :lol:
Thanks,
Adam
PostPosted: Sun Apr 19, 2015 11:30 pm
by Warkton Tornado No.1
Hi Adam et cetera.
Look again @ the pdf parts diagram (VHSH Slide - BS) & I believe you'll see it.
It's a sprung plunger to load the needle on it's side, in the direction of the back of the carb.
So, you should refit it, ideally.
I hope that helps.
Kind Regards
PostPosted: Sun Apr 19, 2015 11:37 pm
Hello again.
Sorry if I've caused confusion, but I should have said that what you see in the pdf is the blanking plug that does the job of retaining the spring & plunger.
I've checked by grabbing one of my carbs, took the slide then needle out & you can see the plunger poking in.
Regards
PostPosted: Mon Apr 20, 2015 10:35 pm
by Adam_Winstone
Thanks for the heads-up, I'll check out my 2 slides and see if you've done it..... thanks.
Adam
PostPosted: Thu Apr 23, 2015 9:22 pm
by Adam_Winstone
Hmmmm, just when I thought we had it! Unlike a number of my VHSA and VHSB slides, neither of my VHSH slides has the drilling in the slide to take a spring + blank, however, I'm convinced that this is exactly what these parts are, thinking that this is likely to have fallen out of a different carb and this is where the confusion has stemmed from :roll:
Thanks for all of the feedback and food for thought.
Adam
