VHSH... what is it?!
Postby Adam_Winstone » Wed Apr 15, 2015 2:00 pm
All,
Last night I stripped down a VHSH 30 to fit to a motor and a tiny little brass part (small solid cylinder about 3mm long) and tiny fitted spring fell out of it. Any ideas as to what it is and where it goes?
Ta
Re: VHSH... what is it?!
Postby Captain Pugwash » Wed Apr 15, 2015 4:36 pm
PM sent
Captain Pugwash
Postby bolzenanker » Wed Apr 15, 2015 4:38 pm
I've got one at home that I've changed jets on before and don't recall anything like that. I'll have another look later if I get a chance and report back.
Warren
bolzenanker
Postby Toddy » Thu Apr 16, 2015 6:27 am
Will this help theres a PDF parts diagram on the link
http://www.dellorto.co.uk/merchandise/p ... ctionID=42
Postby Adam_Winstone » Thu Apr 16, 2015 8:18 am
I couldn't see this part on the exploded diagram but here it is...
Postby Toddy » Thu Apr 16, 2015 12:17 pm
Is it off the threaded bit what screws into the top of the slide that the cable goes through ? doesnt that have a spring underneath (sits on top of the Needle )
Postby Markpm » Thu Apr 16, 2015 12:57 pm
It looks like the choke plunger to me ??
Or an atomiser bush (had a look at diagram )
Markpm
Postby Adam_Winstone » Thu Apr 16, 2015 1:44 pm
It does look like that sort of thing but this (body) is only 5mm long at most, way too small for choke use.
The exploded parts diagram and Eurocarb parts list don't seem to show it.
I'll need to have a really close examination of the carb again to see if I can identify it or where it should go, what it should do. The good news is that the carb seems to work without it! :lol:
Thanks,
Postby Warkton Tornado No.1 » Sun Apr 19, 2015 11:30 pm
Hi Adam et cetera.
Look again @ the pdf parts diagram (VHSH Slide - BS) & I believe you'll see it.
It's a sprung plunger to load the needle on it's side, in the direction of the back of the carb.
So, you should refit it, ideally.
I hope that helps.
Kind Regards
Postby Warkton Tornado No.1 » Sun Apr 19, 2015 11:37 pm
Hello again.
Sorry if I've caused confusion, but I should have said that what you see in the pdf is the blanking plug that does the job of retaining the spring & plunger.
I've checked by grabbing one of my carbs, took the slide then needle out & you can see the plunger poking in.
Regards
Postby Adam_Winstone » Mon Apr 20, 2015 10:35 pm
Thanks for the heads-up, I'll check out my 2 slides and see if you've done it..... thanks.
Postby Adam_Winstone » Thu Apr 23, 2015 9:22 pm
Hmmmm, just when I thought we had it! Unlike a number of my VHSA and VHSB slides, neither of my VHSH slides has the drilling in the slide to take a spring + blank, however, I'm convinced that this is exactly what these parts are, thinking that this is likely to have fallen out of a different carb and this is where the confusion has stemmed from :roll:
Thanks for all of the feedback and food for thought.
