Suzuki 190 conversion jetting help
Postby Olly69 » Tue Apr 07, 2015 5:56 pm
Hi all running a 190 Suzuki conversion 22 delly and clubman pipe anyone running similar set up ? What jetting are you using ? Thanks olly
Olly69
Re: Suzuki 190 conversion jetting help
Postby St George » Tue Apr 07, 2015 6:08 pm
I have a similar set up to that but Yamaha stage 4 with longer con rod , the 22mm could not feed the engine quick enough for that big exhaust. It would not rev very high. Someone on here will prove me wrong. I have put a 30 mm on mine and it flies : )
St George
Postby Olly69 » Tue Apr 07, 2015 6:22 pm
So what pipe are you using ?
Olly69
