Dellorto PHBL 25MM SeT UP
Postby Trojanexplosion » Sun Jun 08, 2014 10:02 pm
Hi currently running a delly phbl 25mm/Remote air filter with a casa 185 kit,
set up
AQ 266 ATOMISER
D22 needle T2 CLIP
40 SLIDE
55 IDLE/pilot
60 CHOKE
108 MAIN
200 FLOAT VALVE
Starts and runs fine but his a flat spot between 3/4 and full.
Anyone running a similar set up with a casa?or am i in the right ball park
Bolty
Trojanexplosion
Re: Dellorto PHBL 25MM SeT UP
Postby Dennie » Mon Jun 09, 2014 1:22 pm
Hi,my setup is similar casa 185 on a series 2 with 42 mm clubman and series 2 175 wide neck airbox and dellorto 25 mm phbl setup as follows:-
104 main
55 pilot
D29 needle 3rd clip
AQ 266 atomiser
60 choke
40 slide
300 float valve
Pulls well through the gears and plug is light brown in colour , hope this may be of some help regards dennie.
Dennie
Postby Trojanexplosion » Mon Jun 09, 2014 8:38 pm
Cheers Dennie very helpful
Trojanexplosion
