which card for an RB20
Postby Scoot655 » Wed Jan 07, 2015 7:01 pm
I'm about to start on an RB20 engine build so amongst other bits i need to know what is the best carb set up to use with the reed valve?do i have to use a flat slide carb or can i mount a solid mount phbh carb to it?!
Scoot655
Re: which card for an RB20
Postby rossclark » Wed Jan 07, 2015 7:34 pm
Most reed blocks use a rubber mount carb so your solid most will not be any use.
Postby Toddy » Thu Jan 08, 2015 7:02 am
rossclark wrote:Most reed blocks use a rubber mount carb so your solid most will not be any use.
^Agreed^ i ran a 30mm Dellorto VHSH flatslide rubber mounted with shortened inlet for better panel clearance on mine
Users browsing this forum: Bing [Bot] and 37 guests
