28ml PHBH four stroking
Postby steve_lawrence » Wed Jun 11, 2025 7:38 am
I recently had an RT195 kit fitted to my Li Special. It has a brand new Dell’Orto PHBH 28ml carb which is proving virtually impossible to set up for a non-spluttery ride. My friend, a motorcyclist and scooter rider for many years has tried many jetting set ups but it has got him beat. The scooter goes well, but once you ease back on the throttle the 4 stroking kicks in. Under load it’s fine, but ease off to steady the speed and that’s when the issue starts. Would a dyno session possibly cure it?
The current set up is 50 pilot, 126 main, X13 needle second clip from the top, 264 atomiser. I’m not using the air box but there’s a foam air filter fitted directly on the carb.
Any advice would be gratefully appreciated.
steve_lawrence
Re: 28ml PHBH four stroking
Postby hullygully » Wed Jun 11, 2025 9:44 am
Ive used a 55/57 pilot in 2 x mates 28mm dellies on rt195's but with open carb
what's your air screw & slide bud, plus exhaust?
have you tried without filter?
Postby steve_lawrence » Wed Jun 11, 2025 1:59 pm
It’s a 40 slide. I’m not near the scooter at the moment so I can’t check the air screw.
steve_lawrence
Postby Adam_Winstone » Wed Jun 11, 2025 9:59 pm
Leaking float with fuel in it?
Postby Warkton Tornado No.1 » Thu Jun 12, 2025 10:16 am
The slide is too rich. Dell’Orto carburettors - perhaps unsurprisingly - tend to need the same slides across the range & 45 is the normal choice.
If possible, borrow a 45 slide to try.
The good news - apart from it having a round slide :roll: - is that the 40 slide is easily convertible to a 45 via material removal from the edge…..
Postby Rich Oswald » Thu Jun 12, 2025 6:03 pm
A 45 or even a 50 slide would probably help your issue.
Postby hullygully » Fri Jun 13, 2025 10:06 am
there is also another range of atomisers, the AS range as opposed to the AV's, which have the same no. range but are slightly weaker :shock:
Postby Adam_Winstone » Fri Jul 11, 2025 1:12 pm
hullygully wrote:there is also another range of atomisers, the AS range as opposed to the AV's, which have the same no. range but are slightly weaker :shock:
^... I've not noted a response to your previous question / suggestion either: "have you tried without filter?"
There are SO MANY inappropriate filters sold by scooter shops. OK, I appreciate that many are selling them as they're meeting a customer demand, which is often too small as customers want a filter that fits under bodywork, without cutting a hole in the panel, however, these small and restrictive filters are not appropriate. A filter should filter out particulates, not provide a barrier restriction that does not allow an engine to take in the volume of air that it is often gasping for! Any efficient filter will filter out the rubbish but not restrict airflow.
My way of assessing whether a filter is appropriate for use is to jet / road test the carb open mouthed (no restriction to intake), then to add any associated filter elements to the intake and to road test again to see how each element impacts on the motor. Any addition that restricts the airflow and gives symptoms of running rich is identifying that your added element is not appropriate. NB: I say any 'filter element', rather than filter, as any air hose or airbox can also be a restriction (regularly are!). PLEASE NOTE that simply reducing the jetting so that a dyno gives the correct AFR ratio actually means that any restriction in air is matched by a reduction in jetting, which gives the right AFR BUT actually provides too little of both (air and fuel), leaving your motor gasping for more of both!
Any decent filter setup will not cause a well jetted open mouthed carb to suddenly start running rich. Before you can assess a filter, you need to have the jetting set appropriately for your specific motor's need... then you can look to introduce and evaluate a filter.
Good luck in getting it sorted.
PS - These are lots and lots of reasons why your jetting could be rich / out but you (Steve) but you could well find that this is a filter issue that will not allow you to jet your carb correctly. Remove the filter, sort the jetting, then reintroduce and evaluate the filter.
PPS - I am a huge fan of running filters on carbs but am horrified by the small / restrictive arrangements that many owners strangle their motors with.
Postby Covboy » Sun Jul 13, 2025 10:23 pm
Out of interest Adam which filters do you use or favour?
Postby Adam_Winstone » Mon Jul 14, 2025 5:41 pm
My personal 'go to' tend to be foam filters, as they're light and keep weight on carb, carb rubber and any hose (application dependent) to a minimum. However, you then need to ensure that the filter can still flow the volume of air required to meet the induction demand. You can do this by:
- Using a foam filter that is relatively free-flowing by the nature of the foam's density. The denser the foam the more particulates it filters out. The less dense = the more particulates go through it and into your engine.. However, too dense or no enough transfer area, you start to restrict t air volume that can make it through in the time available. So...
- Size. Yes, size does matter. A small foam filter will need to be very coarse to flow enough air, whereas a larger filter could be of finer foam and still pass the same volume / time.
So we're into that quandary of how much space you have under a panel, if indeed we're talking about a full bodywork bike. Using a 90 degree hose for remote filter use can allow for a bigger filter option.... but the hose itself, with induction mix needing to slow to turn 90 degrees, can become the restriction. This is exactly why there are many different air hoses on the market... and many different filters.
For me, the Breathe Sweet filter (or similar) from Tino (via Cambridge Lambretta, Scooter Center and others, is my first choice. These are a very good balance of foam coarseness and viable size. These will supply charge enough for most engines, providing the hose is appropriate (standard for smaller demand engines, then the Scooter Center wider version, then the Cambridege or Darrell Taylor hose. Option is often limited by the space that results from your model of bike (S1&2 more space than S3... or panel type on S3) and the combination of carb and manifold.
Postby Adam_Winstone » Mon Jul 14, 2025 5:46 pm
(hit post so didn't lose it!)...
NB: Some of the small foam filters ha ve a double foam construction (coarse outer, fine inner) and I've found these completely strangling standard iron 175s, yet they're sold for all sorts! They actually flow less than the standard paper filter cartridge!!!
^... the above are a good example of needing to ensure that you have an appropriate filter for your motor and bike arrangement.
Postby Adam_Winstone » Mon Jul 14, 2025 5:50 pm
One last thing...
I tend to use a lightweight plumber's angle atop of a hose to locate the filter between tank and toolbox, however, I sometimes use 90 degree hose laying parallel to rear footboard if a long-range tank is used... but space is more limited.
Users browsing this forum: Bing [Bot] and 33 guests
