Mikuni tmx
Mikuni tmx
Postby Jamjo » Mon Sep 30, 2024 12:45 pm
TMX 35 Does anyone know if there should be a spring and o ring /washer on the air screw . The blow up diagram on the web shows these parts but I’ve took mine apart and there isn’t any in place . Any one got any info on this and where I can get said parts if needed
J
Jamjo
Re: Mikuni tmx
Postby Fast n Furious » Mon Sep 30, 2024 4:13 pm
The parts you refer to are:-
O-ring part number:-N133.037 002-858
Washer part number:- VM12/33 002-856
These are not needed on the TMX35 though. Just need the screw and spring.
Last edited by Fast n Furious on Mon Sep 30, 2024 10:51 pm, edited 1 time in total.
Re: Mikuni tmx
Postby Jamjo » Mon Sep 30, 2024 4:34 pm
Hi F and f is the spring needed just to put my mind at rest it hasn’t fallen out :roll:
Jamjo
Re: Mikuni tmx
Postby Fast n Furious » Mon Sep 30, 2024 10:53 pm
Yes you need the spring.
Take a good look down the hole. The spring often gets stuck down there. May need a small screwdriver to persuade it out.
Re: Mikuni tmx
Postby Jamjo » Tue Oct 01, 2024 7:39 am
Thank you will put my glasses on later :D
Jamjo
Users browsing this forum: Bing [Bot] and 33 guests
