22mm Jetex Carb
I recently stripped the 22mm Jetex on my largely standard Li150 to check the jets and slide were correct. I have a reasonably good understanding of how carbs work (mainly Japanese) but was a bit surprised to see the slider did not have a needle. From what i have read the Jetex is a copy of a Dellorto so presumably that lacked a needle as well.
Is this common for two strokes of that era ?
