Suzuki 190 kit + 28mm Dellorto - jetting ball park
Postby Scooterslag » Fri Feb 04, 2022 1:46 am
Got a friend who recently built up such a lump and needs to know a rough idea on jetting. I think the kit is a stage 4 jobby with a 28mm delly PHBH and VW clubman- thanks Paul
Re: Suzuki 190 kit + 28mm Dellorto - jetting ball park
Postby Solid Air » Fri Feb 04, 2022 11:34 am
This is my similar set-up Paul...
30mm PHBH
Pilot: 45
Slide: 45
Needle: x7
Clip: 3
Atomiser: AV266
Main: 120
RM Ex-Box
Hope that helps
Mark
Postby Scooterslag » Sat Feb 05, 2022 12:20 am
Solid Air wrote:This is my similar set-up Paul...
30mm PHBH
Pilot: 45
Slide: 45
Needle: x7
Clip: 3
Atomiser: AV266
Main: 120
RM Ex-Box
Hope that helps
Mark
Cheers Mark- much appreciated :)
Postby Knowledge » Sat Feb 05, 2022 10:29 am
Interestingly, a mate has been in touch asking if I would like to rebuild his DJ190 engine, so this info should be useful
