Jetex 22 carb
Jetex 22 carb
Postby Osti80 » Wed Oct 27, 2021 1:37 pm
Hi lads/lasses,
I am fitting a mid range tank to my golden special which runs through the air box, I plan to fit a ramair filter to accommodate the mid range tank.
When I tried it she ran on half power, and felt restricted.
Can anyone help with regards to jetting her correctly
Many thanks
Osti80
Re: Jetex 22 carb
Postby hullygully » Fri Oct 29, 2021 10:27 am
did you have a filter in your old airbox?
how does it run without the Ramair filter?
Re: Jetex 22 carb
Postby missing lynx » Fri Oct 29, 2021 11:42 am
Is that with the panel on? it could be the panel is crushing the filter between the panel and the tank. Have you thought of using a Chiselspeed panel filter? Or It may be you just need to re jet to take into account the different volume of air the new filter supplies
