Effects of worn reed valve petals?
Postby Scoot655 » Tue Mar 16, 2021 3:37 am
Much needed help required!
What's the effect of worn reed valve petals on a tuned lambretta engine? I`ve got the carb settings to ball park figures but I'm struggling with it still feeling lumpy on pick up and occasionally cutting out for no reason?
Many thanks,
Paul Marshall
Scoot655
Re: Effects of worn reed valve petals?
Postby Tractorman » Tue Mar 16, 2021 9:43 am
Could be, I had a broken one and the scooter wouldn't start.
Postby Toddy » Tue Mar 16, 2021 7:05 pm
Could be electrical ?
Postby hullygully » Fri Mar 19, 2021 5:16 pm
Can you stick a camera down your manifold to check petals?
but I'd check electrics too, usual suspect :roll:
Postby Norrie Bodge » Fri Mar 19, 2021 6:47 pm
Scoot655 wrote:Much needed help required!
Many thanks,
Paul Marshall
Try another CDI(Ducati Type) 1st
Norrie Bodge
Postby coaster » Sat Mar 20, 2021 12:26 pm
Many thanks,
Paul Marshall
They should be good for a few thousand miles, how long have they been in? itll only take 10 minutes to remove them for a proper check
Postby Leotech » Wed Mar 24, 2021 8:57 pm
If reeds were broken it would be very difficult to start on the kick, they could be spit, but like someone says, just whip block out to check reeds visually.
The newest type Ducati CDI seem to have a rev limiter at around 7000 rpm, I found that out on a Vespa site and on the dyno when a pals Lamby hit a wall at 7000 rpm ish.
Leotech
