SH 22 rt set up
SH 22 rt set up
Postby neil64 » Mon Jun 08, 2020 12:14 pm
Hi
just in the process of from a std 200 top end to a RT 225 KIT. im going to use the existing carb ( which has been modified to 24 mm ) with matched manifold . wondered about jetting , currently set as ,pilot 47, main 125. may pos upgrade carb later but just to bed in using the carb as mentioned. pipe is a clubman 42.
thanks.
neil64
Re: SH 22 rt set up
Postby ULC Soulagent » Mon Jun 08, 2020 5:13 pm
Don’t know anyone who’s running a standard carb on an RT kit, best bet is ring Mb and take it from there :roll:
