Jetex flow rate
Hello all,
I'm trying to cure a top-end issue on my Sil 200, reamed Jetex & AF Clubman. I've concentrated so far on the fuel system and have done some checks on the flow rate per Sticky's recommendations. I have more the enough fuel though the tap (fast flow) & hose at 600ml per minute.
I then connected the carb with float and needle valve in place and got 165ml in a minute which is understandably a lot less than from the tap alone.
Question is whether any Jetex experts out there think the flow rate through the carb could give me fuel starvation issues and if so has anyone had joy with drilling out the float valve aperture?
Regards,
Simon.
Regards,
Simon.
