Jetting for 28mm phbh carb
Posted:
Sat May 16, 2020 5:20 pm
by Rocketron13
Good afternoon. Im after some info as to jetting a 28mm phbh carb which ive fitted to a rt195 kit. The kit has a reed valve conversion and running a 60x110 crank and no filter. Many thanks in advance
Re: Jetting for 28mm phbh carb
Posted:
Sat May 16, 2020 6:09 pm
by shane BBoys
Does Broady not offer advice on his kits?
Cheers Shane.
Posted:
Sat May 16, 2020 7:56 pm
by ULC Soulagent
Here is one of my Rt195 piston ported setup with Bgm Mk1 clubman, don’t take it as gospel as no two setups are the same and since ur’s is reedvalved then then all jetting will be higher across the board
Pilot 48
Choke 70
Main 118
Needle X7 top clip
Atomiser AV264
Slide 50
Float 3.5g
Regards
Shane
