Jetting for 28mm phbh carb
Postby Rocketron13 » Sat May 16, 2020 5:20 pm
Good afternoon. Im after some info as to jetting a 28mm phbh carb which ive fitted to a rt195 kit. The kit has a reed valve conversion and running a 60x110 crank and no filter. Many thanks in advance
Rocketron13
Re: Jetting for 28mm phbh carb
Postby shane BBoys » Sat May 16, 2020 6:09 pm
Does Broady not offer advice on his kits?
Cheers Shane.
shane BBoys
Postby ULC Soulagent » Sat May 16, 2020 7:56 pm
Here is one of my Rt195 piston ported setup with Bgm Mk1 clubman, don’t take it as gospel as no two setups are the same and since ur’s is reedvalved then then all jetting will be higher across the board
Pilot 48
Choke 70
Main 118
Needle X7 top clip
Atomiser AV264
Slide 50
Float 3.5g
Regards
Shane
