GT186, 30mm PHBH & Gori Pipe
Postby NorthernJordan » Wed Oct 23, 2019 3:54 pm
Hi All,
I'm trying to help out my uncle with his Gt186 engine as it is hard to start. Tried all the usual tricks such as turning petrol of and leaving it to run etc etc.
So wondering what jetting people are using on similar spec'd engines for comparison.
Thanks!
NorthernJordan
Re: GT186, 30mm PHBH & Gori Pipe
Postby Rich Oswald » Wed Oct 23, 2019 4:10 pm
Hot starting or cold starting?
Postby NorthernJordan » Wed Oct 23, 2019 5:23 pm
From what I can gather it's hot starting. But will confirm.
Jordan
NorthernJordan
Postby coaster » Wed Oct 23, 2019 5:46 pm
Have you checked the reeds?
Postby Toddy » Thu Oct 24, 2019 5:57 am
coaster wrote:Have you checked the reeds?
Think they are usually doubled up on the 186's as well
NorthernJordan wrote:Hi All,
Thanks!
What Carb Jordan ?
Postby ULC Soulagent » Thu Oct 24, 2019 7:38 am
Thanks!
What Carb Jordan ?
It’s in the title Toddy ;)
Postby Toddy » Thu Oct 24, 2019 8:20 am
Thanks!
What Carb Jordan ?
30mm phbh scootopia pipe
Main 135
Pilot 55
Choke 70
Needle x13p2
Slide 40
Atomiser av268
Float valve 300
Postby NorthernJordan » Thu Oct 24, 2019 8:55 am
I've never really used reeds before. What would I be looking for, splits? Chips of the end of the petals?
I think the engine has only done baout 500 miles. So had discounted things like rings for the time being.
NorthernJordan
Postby Rich Oswald » Thu Oct 24, 2019 9:39 am
Is it running a filter as I set a new engine up with a breathe sweet which wouldn't start hot, changed to a Chiselspeed panel filter and it was fine so I think it was due to the spitback and subsequent flooding due to the collection of fuel in the rubber elbow.
Postby Toddy » Thu Oct 24, 2019 9:46 am
Jordan yes and bits missing ;)
Postby martyn dwane » Thu Oct 24, 2019 11:19 am
choke not closing off properly?
had this on one of mine, really hard to start when hot, had my clubmates bumping me around our meet carpark, new choke cable ,set with a" little "slack in the cable been good ever since.
martyn dwane
