PHBL25 on Li150
PHBL25 on Li150
Postby foremanbob » Sat Jul 13, 2019 9:21 pm
Anybody any idea on Jetting for a PHBL25 on a standard 150
Currently
60 Choke
50 Pilot
D22 Needle 2nd Clip
85 Main
foremanbob
Re: PHBL25 on Li150
Postby shane BBoys » Sat Jul 13, 2019 10:43 pm
I’d drop the choke to 45 and the pilot to 50.
No prove of this other than somewhere near a Muggy 186.
See how you go.
Cheers Shane
shane BBoys
Re: PHBL25 on Li150
Postby Rich Oswald » Mon Jul 15, 2019 10:22 am
shane BBoys wrote:I’d drop the choke to 45 and the pilot to 50.
See how you go.
Cheers Shane
Shane, are you sure you don't mean the other way round ie: choke to 50 and pilot to 45?
Re: PHBL25 on Li150
Postby martyn dwane » Mon Jul 15, 2019 11:38 am
what atomiser are you using ?
martyn dwane
Re: PHBL25 on Li150
Postby foremanbob » Mon Jul 15, 2019 3:49 pm
AQ266 Atomiser
foremanbob
Re: PHBL25 on Li150
Postby ULC Soulagent » Mon Jul 15, 2019 4:01 pm
foremanbob wrote:AQ266 Atomiser
Bit rich for a standard 150 I’d imagine
My settings on an Rt200 reedvalve below
25 delly
112 main
70 choke
45 slide
50 idle set 2 turns out
D22needle
AQ 266 Atomiser
300 float jet
Re: PHBL25 on Li150
Postby foremanbob » Wed Jul 17, 2019 8:42 pm
Thanks chaps... first experience in trying to set one of these carbs up...
Mate just bought scooter... The seller had bodged a big block manifold onto the Li150 barrell, and used a bit of car radiator hose as the manifold rubber...
I'm having to check everything now...
foremanbob
Re: PHBL25 on Li150
Postby AndyVee » Tue Jul 23, 2019 3:02 pm
Hi, can I ask did you get this tuned in - just starting to do exacty the same thing and a known set-up would be helpful to get started. Only difference I have is that I have a 42mm Clubman , but doubt it will make that much difference . . . Cheers
AndyVee
Re: PHBL25 on Li150
Postby foremanbob » Tue Jul 23, 2019 4:44 pm
Will let you know once I've sorted out the starting issues.....
foremanbob
Re: PHBL25 on Li150
Postby Charliebubble47 » Thu Dec 12, 2019 4:06 pm
Hi Bob
Did you get this sorted and what was the final set up
As I've got something similar and was looking for a good starting point
C
Charliebubble47
