pwk filter
pwk filter
Postby neil64 » Tue May 07, 2019 8:29 pm
hello.
anyone running a pwk 28 mm with an air filter . if you are , what type suite and do you have to down jet ?'
cheers.
neil64
Re: pwk filter
Postby Solid Air » Tue May 07, 2019 10:12 pm
Have used both a Marchald foam filter and a MBD tea-strainer on a 28mm PWK, but that did need the collar from the Marchald to fit it. Can't remember accurate jetting info though I'm afraid.
Mark
Re: pwk filter
Postby a.lo » Tue May 14, 2019 9:06 pm
I use a Breathsweet and it dosn,t seem to affect jetting although this has never been tested on a dyno
a.lo
