Throttle Cable Change
Postby Granty » Mon May 06, 2019 10:32 pm
Changing my set up, swapping a standard jetex for a dellorto PHBH, on the traditional side - RHS looking at the bike. Do I need to change the throttle cable to an extra long one & then re-route as a matter of course? Cheers G
Granty
Re: Throttle Cable Change
Postby Tractorman » Tue May 07, 2019 7:38 am
Not if you get a 90 degree bend, you will need a new inner because it's longer on the PHBH and the solder less nipple is at the headset end.
Postby missing lynx » Tue May 07, 2019 7:37 pm
Also if you drill the throttle wheel so the cable can pass through the solderless nip and the throttle wheel it makes it much easier to fit the cable
