Carb trumpet on a 28 dellorto
Postby Topgearskin » Mon Apr 22, 2019 1:29 pm
Anyone fitted an old school trumpet onto a 28mm phbh delly?
I appreciate it's an old fashioned thing to do on a modern carb, but I don't want an air filter or an oily footboard. Running an RT smallblock kit and a BGM clubman.
Topgearskin
Re: Carb trumpet on a 28 dellorto
Postby Rich Oswald » Tue Apr 23, 2019 9:16 am
I did on the J230 and loved it but having short legs I found I was covering it at every junction etc and it would cut out so changed to a foam filter,
Postby Topgearskin » Tue Apr 23, 2019 8:54 pm
Thanks rich. Was that a screw on type or did you clamp on a generic trumpet?
Topgearskin
Postby Rich Oswald » Wed Apr 24, 2019 9:25 am
Topgearskin wrote:Thanks rich. Was that a screw on type or did you clamp on a generic trumpet?
It was secured by grub screws.
Postby Topgearskin » Wed Apr 24, 2019 6:05 pm
Topgearskin
Postby Digger » Fri Apr 26, 2019 6:54 am
Been running a screw on one with a gauze on a Rapido 225 for years. :D
Digger
Postby Topgearskin » Fri Apr 26, 2019 4:34 pm
Any link to where I could buy one chaps?
Topgearskin
Postby Scooterdude » Fri Apr 26, 2019 6:10 pm
Topgearskin wrote:Any link to where I could buy one chaps?
eurocarb.
Scooterdude
Postby Cgt75b » Thu May 16, 2019 6:00 pm
I run a trumpet on a 25 mil dellorto, I purchased it from like the comment says above eurocarb.
https://www.dellorto.co.uk/
Postby rossclark » Fri May 17, 2019 12:24 am
There is nowt modern about the PHBH... :D
Postby Topgearskin » Sun May 19, 2019 8:41 pm
rossclark wrote:There is nowt modern about the PHBH... :D
Everything's relative
Topgearskin
