phbh26. float weight
Postby collector1967 » Thu Aug 28, 2014 6:33 pm
My Dellorto phbh 26mm has a 11 grm float, is that correct, my other scoot with same carb had a white float, this is black .
Thanks Ian :?
collector1967
Re: phbh26. float weight
Postby Dimitrios_231 » Sat Aug 30, 2014 11:31 pm
The newer white floats come in 3 different weights,
6.5gr
9.5gr
12.5gr
See the link
http://www.dellorto.co.uk/merchandise/p ... ctionID=24
Two stroke engines usually work better with the lighter floats,
I believe that the 6.5gr is the one you should choose.
The 9.5gr might also work but try to avoid the 12.5gr.
Dimitrios_231
Postby collector1967 » Tue Sep 02, 2014 9:45 am
Thanks for the info, very helpful
Cheers Ian ;)
collector1967
