RT Carbs
RT Carbs
Postby rossclark » Sat Feb 09, 2019 1:08 am
What carbs are you using on your RT225?
I've just got one, inc. the flange manifold, which will be going on my Lince.
The gearing will probably stay 4.8 SX, I have a no name clubman and a JL3 curly as exhaust choices.
I'd also prefer to run a filter.
Looking for solid recommendations for carb ideas - I have a TM30 and a couple of OKO/ Koso PWKs (24 & 30), these are a bit unknown to me but would be prepared to listen to something other than PHBH / PHBL set ups.
Not looking for a screamer just a steady, reliable set up.
Cheers.
Re: RT Carbs
Postby ULC Soulagent » Sat Feb 09, 2019 2:56 pm
I’ve got the rt 230 reedvalve ttt on my scoot
Bgm V3 clubman
SX gearing
Delly phbl 25 with casa power filter
Runs sweet cruising 60/65 and tops out 75 returning 130 miles on a 11lt tank
Only other carb I’ve used is the vhst 28 which has been a right pig too setup.
Sorry this doesn’t help ur decision making :roll:
Re: RT Carbs
Postby rossclark » Sat Feb 09, 2019 3:04 pm
Interesting to know that's what it can do on that gearing, and without going to the 30mm, cheers.
Re: RT Carbs
Postby rossclark » Wed Feb 13, 2019 11:09 pm
Given there doesn't seem to be much in the way of alternative opinion I've gone with what appears to be the tried and trusted PHBH30
Re: RT Carbs
Postby Scooterdude » Thu Feb 14, 2019 8:51 am
I went from a phbh 28 to a phbh 30 on my RT reed and saw a marked improvement right across the range.
Scooterdude
