Engine won't rev out
Postby Paul_from_Thornbury » Sun Aug 24, 2014 3:41 pm
Got LI150 engine converted to MB RT195, with Clubman exhaust and 24mm PWK.
Had jetting done by Paul Baker at SRP race tec at the beginning of summer.
Had carb off yesterday to try and change flip up choke to cable choke and after discussion with Paul via text a minor change to needle setting.
However now the engine won't rev out, gets to about 1/2 revs and then just hunts, pulsing up and down in revs. Sometimes it will also rev away to very high rpm even with throttle closed off and have to put hand over carb to shut it down as turning off ignition doesn't stop it.
Only time I have had this before is with a split carb rubber, but it's ok on this occasion.
Returned all to settings that Paul had set and back to flip choke but it's still the same.
The only other change since the set up at SRP is a change in stator plate and CDI after breakdown.
Paul_from_Thornbury
Re: Engine won't rev out
Postby CHRIS in MARGATE » Sun Aug 24, 2014 5:05 pm
Is the cable nipple still held in firmly in the slide?
Also check has the circlip come off the needle?
Has the pin come out of the float ?
Postby Paul_from_Thornbury » Sun Aug 24, 2014 5:41 pm
Yes slide moves fine, no circlip has not come off and float bowl is fine.
Spoken to Paul Baker and he suspects the stator although green/white and red/white resistance readings seem normal at 532 and 110 ohms but these may be breaking down under high demand when revs are high. I have changed plug lead and CDI, so will put new LT coil on my currently unserviceable spare stator.
Paul_from_Thornbury
Postby coaster » Sun Aug 24, 2014 6:00 pm
The stator won't cause the engine to over rev, that sounds more like an air leak, I'd have another look if I were you, make sure the rubber is fully seated in the grove if it has one. Also don't over tighten the Jubilee clips, just tight enough to hold the carb from twisting, over tightening can cause distortion.
Postby Paul_from_Thornbury » Sun Aug 24, 2014 6:48 pm
Checked that, they are not over tight. Top of engine below fuel tank us a bit wet, but I'm convinced that is fuel tank spillage. Have dried off to ensure that there are no gasket leaks, but when I rebuilt all was torqued correctly with new gaskets, I'm sure there would be a noticeable performance deficit if it was a base gasket, inlet gasket or magneto gasket issue.
Paul_from_Thornbury
Postby coaster » Sun Aug 24, 2014 11:44 pm
Well if it was running ok before you worked on the carb and now it isn't it must be related to what you have with the carb.
Postby Paul_from_Thornbury » Tue Aug 26, 2014 7:09 pm
http://youtu.be/2tCVuP9XzI0
Attached is a youtube link which is a sound recording of the engine being initially held at 1/2 throttle and the second at full throttle, the engine won't rev out and has the 'pulsing' of the engine hesitating.
I have ordered a new stator today, I have tried to BGM stators, but want a new one to baseline from.
Paul_from_Thornbury
Postby CHRIS in MARGATE » Tue Aug 26, 2014 7:35 pm
I am just re-reading and didnt notice first time that you wrote ignition switch would not kill engine and it revs up. Classic sign of pre-ignition where excessively weak mixture caused piston crown to heat up and detonate fuel without a spark.
I might be wrong but it happened after carb was taken off, so I am still going with that.
Hope you get it sorted.
Postby sunrisemac » Tue Aug 26, 2014 9:39 pm
For the engine to rev up with the throttle closed it would need to be getting plenty of fuel from somewhere.
sunrisemac
Postby rossclark » Tue Aug 26, 2014 10:27 pm
sunrisemac wrote:For the engine to rev up with the throttle closed it would need to be getting plenty of fuel from somewhere.
Classic air leak symptom, racing on a closed throttle, lean running it gets so hot that the fuel ignites without a spark
Postby Paul_from_Thornbury » Thu Aug 28, 2014 7:47 pm
New stator fixed problem, so looks like I have two BGMs with dud pickups. When I spoke to them they said it was a rare failure and the chances of having two with failed pickups was very slim.
The over revving I'm guessing was coming from the engine taking great gobs of fuel/air mixture that it wasn't igniting due to the pickup failure
Paul_from_Thornbury
Postby Adam_Winstone » Thu Aug 28, 2014 8:19 pm
I wonder if this was a pickup failure or LT coil failure? likewise, with BGM's good reputation, I'd have thought 2 x component failure was unlikely. I wonder whether the height from underside of stator plate to pickup triggers was the same on all 3 stators or whether the height of trigger differs and alignment of stator to flywheel could be a factor?
Postby sunrisemac » Thu Aug 28, 2014 9:45 pm
I do know a bit about engines I build race cars for a living, fuel won't ignite if there's none there, the engine can run on very lean with the throttle closed but is unlikely to rev up for long and run faster without more fuel.
Glad to see the problems been sorted, it seem that Eden knows his stuff he was spot on
sunrisemac
Postby CHRIS in MARGATE » Thu Aug 28, 2014 10:16 pm
Pleased for you. Well done.
